Classical Music Compressor
  • Classical Music Compressor
    Classical Music, especially orchestrations, often exhibit a very wide dynamic range. This is fine when listening to that material in the comfort of your easy listening chair at home. However, when driving in a car and listening to this type of material, the quiet passages often get lost in the road noise and the crescendos can be window-shattering.
    Here is a multifilter preset that solves that problem while maintaining the overall quality of the source recording. It brings up the soft passages on a multi-band basis while limitiing crescendo loudness.
    Install this in your Diamond Cut Productions Multifilter presets folder. It is called "Classical Music Compressor".
