88.2 Impulse-CNF-VPA
  • 88.2 Impulse-CNF-VPA
    Here's a preset if you want to try running the impulse filter before conversion with the VPA. I also put the CNF in there before the VPA. I got excellent results with this on Rahssan Roland Kirk's "Other Folks' Music" lp. The lp has flute, harmonica, all sorts of saxophones and horn/woodwind variants, drums and piano. You'd want to just use this as a starting point. Your settings would likely be different.
    88.2impulse.zip
    BTW - as a sidebar - Dan told us that he transferred the LP using a flat preamp to create the above preset. He used an 88.2 kHz sample rate.
