Here is a preset that will produce a real time, hard knee clipping action on a wavefile. It works only with the Forensics version of the Diamond Cut Software because it uses the Polynomial Filter. You should first adjust the signal level (using the gain change feature) of your audio material to be peaking out around - 3 dB for this to work properly. Then apply the filter.
Real Time Hard Knee Clipper
