Here is a preset that will produce a real time, soft knee clipping action on a wavefile. It works only with the Forensics version of the Diamond Cut Software because it uses the Polynomial Filter. You should first adjust the signal level (using the gain change feature) of your audio material to be peaking out around - 3 dB for this to work properly. Then apply the filter.
Real Time - Soft Knee Clipper
Last edited by Craig Maier; 08-02-2019, 10:07 AM."Who put orange juice in my orange juice?" - - - William Claude Dukenfield
