Here is a Multifilter Preset which can be used with a Stanton 500 cartridge in conjunction with a "Flat" phono preamplifier transfer. This preset will not only convert a flat transfer using a Stanton 500 to RIAA, but will also compensate for deficiencies in the flatness of response of the Stanton 500. This was accomplished through the use of a test record made by "Hi-Fi News" in conjunction with the Diamond Cut Spectrum Analyzer. They call the test record product "Analogue Test LP" (a novel name). Hi-Fi News is an English audio publication.
So, re-iterating, if you have a flat phono preamplifier and a Stanton 500 phono cartridge, this will convert the response to a more perfect RIAA curve since the response of the phono cartridge is also accounted for with this preset.
The Stanton 500 was chosen for compensation because it is very popular, commonly available, relatively low in cost, and can be outfitted with LP and 78 stylii.
Enjoy![Smile](https://www.diamondcut.com/vforum/core/images/smilies/smile.png)
Note: To assure the best performance with your Stanton 500 or any other phono cartridge, it is important to set it up correctly. The cartridge must be aligned properly in the headshell via the use of a special protractor. The turntable should also be level and the anti-skating set for a neutral balance on an ungrooved rotating surface. In other words, the phono arm and cartridge should remain wherever placed on an ungrooved surface provided that the anti-skating is properly set. Also, note that under-weight tracking can be just as damaging to a record and stylus as an over tracked (too heavy) unit.
Enjoy
