DCTune Library gets lost sometimes using the DCTunes Default pathway
  • DCTune Library gets lost sometimes using the DCTunes Default pathway
    Occasionally, we have noticed that the DCTune library gets lost (null set). Rick recommends the following if you encounter this:
    You should try to set the Tune Library Path to a different directory.
    By default mine is set to C:\Users\Rick\Documents\DCart11
    Not sure where yours is set to, but I would make a new directory somewhere in your Documents folder.
    Rick
