Window Menu
  • Window Menu
    -The Window Menu The Window Menu contains all of the commands that affect the manner in which the files are displayed to the user. The following commands are available: Cascade The "Cascade" command arranges all of the open Windows so that they appear on the display one behind the other. The most recently opened Window will appear on top, with the remainder arranged in the order in which they were opened. Tile The "Tile" command arranges all of the open Windows so that they appear on the display in a matrix configuration (in the same plane) on your display. This feature is used when you need to see all of the workspaces concurrently. Arrange Icons The "Arrange Icons" command will arrange all of the "iconized" windows in a row near the bottom of the workspace. Close All As the name implies…click here to close all Windows and Files via one command. Open Files A listing of all of the open files is provided at the bottom of the Window Menu. The file that is active will have a check mark indicated to the left of the file name.
