Channel Toolbar
Just beneath the filter and effects toolbar and towards the left of the display can be found the Channel Selector Toolbar. This allows you to choose which channels are to be operated on by the system. Your choices are as follows:
1. L/R (Both channels)
2. L (Left channel only)
3. R (Right channel only)
The Channel Selector applies to all Filters, Effects and Editing functions accept for tools that change the overall length of the file. Generally, one would tend to leave this feature in the L/R (Both channel) position unless dealing with special editing or sound restoration issues.
Note: You can click on any of the Channel controls while playing to select either the Left, Right or Both channels. When previewing a filter, both channels will always be previewed, but only the channel selected before the preview starts will be affected by the filter.
