DC Tune Library
  • DC Tune Library
    DC Tune Library
    The DC Tune Library provides you with a full-featured audio file archive capability within the context of your DCArt10 or Forensics10 software. It will search your hard drive and find all audio files and store their path, name, genre and other pertinent data within its file structure. After this database is constructed, it provides lightning speed access to any of your audio files, whether they are in .wav, mp3, or wma format(s). You can search your database, order it in terms of various parameters and create and recall playlists. You can play any file directly through the normal play features of your Diamond Cut software, or you can listen to a file or series of files by using the Preview feature found on the Diamond Cut filters and/or effects. You can even listen to the database by way of a complex series of filters and effects by previewing a file via the DCArt10 or Forensics10 Multifilter.
    Details pertaining to the various functions associated with the DC Tune Library can be found in an earlier section of this users guide dedicated to this topic.
    The DC Tune Library Spreadsheet Display
