The View Menu
  • The View Menu
    The View Menu
    The View menu allows you to access the commands that affect the manner in which files, controls, and parametric displays are presented to the user. To activate a particular feature, click on it with the left mouse button. Once it has been activated, a check mark will appear next to the chosen command (feature).
    Toolbars and Docking Windows
    The Toolbars and Docking Windows provide you with a great deal of flexibility with regard to the look and feel of the user interface. It includes controls over some of the commands, the toolbars, the keyboard assignments, and so forth. Of particular interest are the toolbar selectors. On the most basic level, simply check the box associated with the toolbar that you want to show. Of special interest is your ability to turn on or off the Tasks Pane via it’s checkbox.
    Toolbar Selector Dialog Box
    Further personalization of the system can be had via the “Customize” checkbox. It brings up numerous options that you can choose between via the Customize dialog box.
    The Customize Dialog Box
