Reverse File Function
  • Reverse File Function
    Reverse File
    The Reverse file feature does just that - - - it converts a .wav file so that it will play in reverse. This has several uses:
      1. Sometimes, file reversal is beneficial for removing stubborn ticks or pops with any of the Impulse Filters. By running a reversed file through an impulse filter, sometimes clicks that were otherwise too difficult to detect, may be found and removed. Of course, when the process has been completed, you must reverse the file again, so that it may be heard in the normal forward direction.
      2. The Reverse File feature may be used for reversing metal stamper recordings that have been transferred on standard turntables that were not capable of running in reverse. Simply record the metal stamper which is reversed (using the appropriate bi-radial stylus), and then run the “Reverse File” feature to correct the transfer for forward playback.
      3. Professionally recorded master tapes are sometimes stored with “tails out”. If they have been in storage for very long periods of time, there is a risk of losing oxide during the rewind process. So, it is of benefit not to rewind the tape, but to play the tape backwards while transferring it to your hard drive. It will sound reversed, but can be restored by using the reverse file feature.
      4. It provides an interesting effect. Of course, it can also be used to make sure that there are no demonic subliminal messages recorded in reverse on the music that your children love to listen to!
