Equalizers
  • Equalizers
    Equalizers
    The primary Diamond Cut equalizers are found within a sub-group called “EQ” under the Filter menu. The commercial version of the product includes 4 Equalizers while the Forensics version includes a total of 5. For example, the Forensics version includes a 10, 20 and 30 band graphic Equalizers and a paragraphic Equalizer (a parametric EQ that plots it’s frequency response). Additionally, a 3 band equalizer can be found within the Virtual Phono Preamplifier, which includes bass, mids and treble controls. Its bass and treble controls are of the shelving type (James-Baxandall type) while the mids are of the peaking (2nd order resonant) type. All of the Diamond Cut EQs use IIR techniques to achieve their result. Here is what the EQ menu looks like after the down arrow is clicked and expanded:
    The EQ Menu in its expanded state
    Note: Virtual Phono Preamp (VPP) has an additional 3 Band Equalizer which includes bass, mids and treble controls.
