File Split and Recombine
  • File Split and Recombine
    Sometimes it may be desirable to split a stereo .wav file into its left and right components, establishing individual .wav files for separate channel processing. For example, if one of the stereo channels needs some equalization but not the other, using this splitting and re-combining tool can facilitate that function. This easy to use tool allows you to either Split a Stereo file into two Mono files or combine two Mono files into one Stereo file. You can select whether or not to open these files after the process is complete. Note that the L/R buttons on the toolbar allow instant selection of either or both channels for playing and processing.
    Easily Split and Recombine files with this feature
