Display Preferences
  • Display Preferences
    Display:
    1. Check “Don’t use peak files (.pkf) for display” (no time display shown when checked). This does not apply in Fast Edit Mode.
    2. Check “Sync Mode Scroll Tracking” (synchronizes Source and Destination displays)
    3. Check “Clean Display” which removes .wav file path name from the display
    4. Check “Show Splash Screen on Startup” (this feature saves time following software launch when turned-off)
    5. Display Colors: This set of parameters allows you to choose the Source and Destination Workspace background, highlighted, and waveform colors. When you click on either parameter, a color palate will appear, and you can click on the color combinations that suit your vision (or personal taste) the best.
    6. Display Time Format (X-Axis)*:
      1. Minutes: Seconds
      2. Samples
    7. Display X-Axis Time Scale (checkbox)
    8. Display Y-Axis Amplitude Scale:*
      1. Samples
      2. dB
      3. Percentage
    9. Display Font Size (Enter desired value in terms of “points”. The range is from 2 to 16.)
    10. Sync Mode Scroll Tracking (synchronizes the Source and Destination mode scrolling in Classic Edit mode).
    11. Don’t use Peak Files for Display checkbox – turns off the time domain display when checked.
    12. Lock Markers – Prevents your Markers from being accidently moved when this box is checked.
    *Note: These user selectable parameters are reflected both in terms of the displays but also exportable values where applicable.
    Spectrogram:
    Note 1: Please refer to the Spectrogram section of this manual for details.
    Note 2:Left mouse double clicking in the Spectrogram window can also access the Spectrogram preferences.
