Append to End
Paste Clipboard Contents Directly To End of a File
The "Append to End" feature takes whatever file or portion thereof you have copied onto the clipboard and attaches it to the end of the displayed .wav file. The resulting file will become larger so you may have to zoom-out to see it in its entirety.
Insert at Start
Paste Clipboard Contents Directly to the Beginning of a File
The "Insert at Start" feature is the complimentary function to the "Append to End" feature. Simply stated, it takes whichever file has been copied to your clipboard and attaches itself to the beginning of the displayed .wav file. As a result, the total newly formed file length will become larger so you will have to zoom-out to see it in its entirety.*
Insert at Start
