Cut command
  • Cut command
    Cut
    Just as the title implies… Cut allows you to highlight an area of your file and then remove it from that file. For example, this feature is useful when it is necessary to reduce the musical portion of a segment for a competitive event in which the total length of the musical program is governed, and you do not want to eliminate either the beginning or the end of the song to achieve that end. Additionally, it is useful for eliminating long sectors of silence from Forensics files. You can also access this function by using the Ctrl + X hotkey.
