Clone Source
Quickly copy a .wav file from the Source to the Destination Window
This feature takes whatever .wav file exists in the Source Window and replicates it in the Destination Window. It is only applicable in the Classic Edit mode and not the Fast Edit mode. It is particularly useful when operating the system in Selective Filtering Mode. Highlighted areas of the Source file that are selectively filtered will be modified in the corresponding time slot of the cloned file found in the Destination window.
Note: Sync files mode (found under the View Menu or via the Sync Files Icon) must be enabled for Selective Editing to work properly in Classic Edit mode.
