Close Destination
This command allows you to close a file when operating in Classic Edit mode that has just been processed from the Source file. The working Destination file will have been stored on a temporary basis in a dctempxx.wav file. When you attempt to close the Destination file, you will be prompted to indicate whether or not you want to save it. If you do, then you will be prompted to define a path and a name for your processed file to be saved in.
