Save Destination As
  • Save Destination As
    Save Destination As
    Since DCArt10/DC Forensics10 does not require the Destination workspace file name to be defined before your audio processing session, this command is used to define a Filename and directory location for your Destination file following the completion of an audio processing session, should you desire to save it. This function can also be activated by using the file folder icon in the File Tool bar of the workspace or by using the Ctrl + S hot key. Note: It is almost never necessary to manually save a file in the Classic Edit Mode. The program automatically does this for you.
