Import Playlists
This feature allows you to search your hard drive and import playlists into your DCArt10 software. It will search your hard drive for playlists in the .wls, .m3u and .cue formats and convert them into the .xml format for compatibility with the DCArt10 or the DC Forensics10 system.
