Playing CDs using the DCTune Library
  • Playing CDs using the DCTune Library
    Playing CDs using the DC Tune Library
    You can play CDs (Red Book Audio) using the DC Tune Library. Simply place your CD into your optical drive. After the drive “spins-up” (which will take a few seconds) double click on the words “Audio CD” which is in the “tree” listing within the left-hand column of the DC Tune Library display. You should then see the following appear as part of the tree:
    “Audio CD: xx:yy”
    where xx:yy is the length of the CD in minutes and seconds. Single clicking on “Audio CD: xx:yy” will then construct a listing of the tracks which will appear in the right-hand display of the DC Tune Library. To play these CD tracks, just click on the play button located on the tool bar. Most of the various controls previously described and associated with the DC Tune Library also apply to the CD Player (including Shuffle Play). However, the Multifilter does not work in conjunction with the CD player.
