Playlist Export Feature
  • Playlist Export Feature
    Your Playlist can be exported into other programs that permit importing data such as disc label makers and CD-ROM printing programs. The feature will export the following parameters:
      1. Title Number in sequence
      2. Title of Selection
      3. Length of Time of Selection
      4. Total Length of Time of the Selections
    Clicking on the Export button found on the right mouse button activates this feature which allows you to save it in a number of formats. When you click the Export List button, you can specify a file name. The default will be saved in the *.txt format which can be opened by many other programs. It can also be saved in your choice of other formats including .m3u, cue and .pls (sometimes referred to as M3U, CUE, and PLS).
