Playlist properties
  • Playlist properties
    The Playlist Title Box
    The playlist will be stored in .xml format in the following directory:
    - - - \My Documents\My Music\DCArt10\DCplaylists
    The new playlist will now show up in the left hand margin of the DC Tune Database under “Playlists”. To play a desired playlist, click on the desired item, and then click on the “Play” button on the Diamond Cut toolbar. But, there are also a number of other options available to you on the menu which appears when you click the right mouse button on a particular playlist item:
    1. Create New Playlist (using the existing one as the base)
    2. Rename This Playlist
    3. Delete This Playlist
    4. Export This Playlist (dialog box provides export format alternatives)
    5. Burn a CD from this Playlist
    6. Run Batch Processing on this Playlist
    You can also import pre-existing playlists having the following extensions:
    .m3u,.wls (the older Diamond Cut Playlist Format), .cue and .pls. (These formats are sometimes referred to as M3U, WLS, CUE and PLS.)
    To access this feature, go to the File Menu (of the spreadsheet display) and then go to “Import Playlist”. The system will convert the imported format into the required .xml format.
    The system allows you to view and modify some of the properties of a particular file. To do so, right click on the file of interest in the DC Tune Library and then on “Properties”, and a dialog box will appear as shown below:
