The much anticipated albums called "Novelty Tunes of the Roaring 20's" (Volume 1 and Volume 2) have just been released. They can both be found in the Diamond Cut Music Store located at the following link:
https://www.diamondcut.com/st3/product-category/music/
http://www.diamondcut.com/store/inde...=index&cPath=2
You can hear 20 snippets from each album there (40 in all) and you can buy the music electronically from the music store.
Volume 1 are tunes taken from Electrical Edison Diamond Discs while Volume 2 are taken from Edison Lateral Discs (thin cut test pressings). Both of these compilations are the result of extensive archival transfer work coupled with 18 years of audio software development. The latest Diamond Cut audio restoration software (DC8) was used on both of these new compilations to assure the highest possible audio quality.
So, transport yourself back in time to a care-free era in American History via it's music.
Here is a desctiption of Volume 1:
Novelty Tunes of the Roaring 20s, Volume 1 is a compilation of popular music that captures some of the light-hearted side of those times as recorded on the Edison Label (Edison Diamond Discs) via the newly developed electrical recording process. With the victory of the First World War behind them, the working class of America in the 1920
