Don't seem to be able to turn down the gain control when recording and keep pegging out the meters
gain control
Re: gain control
You must reduce the gain using the routines that came with your sound card. Diamond Cut does not control this function. Have you looked into your sound card software in order to accomplish this? Give it a try. Should work."Who put orange juice in my orange juice?" - - - William Claude Dukenfield
