Obtain a copy of some "CD Ripping" software. I understand that this can be obtained on the internet from many sources. This will allow you to "rip" the red book audio off of the CD converting it to .wav files. That is the file format that Diamond Cut software works with. Then you process the .wav files and if you like, re-burn the CD using the software that comes with your computers CD ROM burner (assuming that you have one.)
working from CD-R files?
