Hello folks;
I have a recording (which is a choral group recorded in the 50's I believe) that has a difference in gain of about 1-1 1/2 db between the 2 stereo channels (R channel is lower than the L channel). Can I select just the desired channel and raise that gain to match the other channel? I believe there is an option to do so in the menu???
Or is there a better way to accomplish this?
Thanks...
-Drew
Thanks...
-Drew
