DCArt10.51 is now available and posted on the Diamond Cut Productions site
  • DCArt10.51 is now available and posted on the Diamond Cut Productions site
    Version DCArt10.51 has been posted. It is a free update for all DCArt10.50 customers. You will not have to re-register for this to work. Just un-install the previous version and install the new one. It includes the following:
    New Update version to DCArt10.51
    • Dozens of new Presets to support for our Flat Preamp
    • Improved default presets
    • Added presets to the Change Speed system
    • New presets in the Virtual Phono Preamp and the Multifilter specifically to support flat preamp transfers
    • All CNF presets have been re-done with re-sampled noise fingerprints; these all produce improved results
    • All CNF presets now have a normal version and a Lite version for improved versatility
    • New Live Log Output feature to log your processed live recording.
    • New Task Pane to start flat phono preamp recording
    • Bug Fixes
    It can be found at the following link:
    https://www.diamondcut.com/Downloads/DC1051Setup.msi
