I'm starting to think about my next restoration/archiving project. The project I am working on now is from an audio cassette source, so manual interpolation has been useful in fixing dropouts, short phasing sounds, etc. I used to have a version of DCart many years ago and used it to transfer some records to my PC. I used the filters exclusively to fix any pops/clicks, but I don't recall ever using manual interpolation. I'm not sure if it wasn't a feature or I just didn't know about it.
Anyway, my question is whether the filter is the same thing as interpolation automatically carried out, or is there more to the filter than that. I tend to use the filters as lightly as possible, and as specifically as possible. So if I hear a click, I select the area then start working with the filter to eliminate it, but you have to play with the settings a lot to find a setting that doesn't alter the sound as well. If I could just zoom in, select the click precisely and hit the I key, that would be very useful to me as I tend to target specific instances of audible clicks/noise, but as I said, I'm not sure if the filter is doing something that interpolate is not doing.
