Restoration Contest Dry Run Sample - "Moaning Low"
  • Restoration Contest Dry Run Sample - "Moaning Low"
    A dry run sample along with my preset for its restoration can be found on the Preset Exchange Area of this bulletin board. It is found under the heading of {"Moaning Low" Contest Sample Preset.} Please read the text carefully before proceeding with the sample restoration of this wavefile. This restoration is intended to be used with the DC 5 or Live / Forensics version of the program only. If you do not own those versions, you can download the free demo of one of those to programs. Since all of the file snippets will be less than a minute long, you will be able to compete in the contest even if you do not own the software. Doug and Rick will be posting the actual contest wavefiles shortly. Good Luck!!
