I've just installed the DiO 2448, and I can't make it work with DC Millennium. Millennium allows me to select it as an input device, but all I get is random bits. I know the signal is there, on the S/PDIF cable, as my SB Live! card is quite happy with it. The following is part of a long message I received from M-audio, and seems to be the only thing which might be affected by DC Millennium:
ASIO or EASI based harddisk recording
software, if you use Windows application
with no ASIO or EASI support please use
driver version 4.x, many applications
support WDM-based drivers only in 16 bits,
not in 24 bits.
Is this a possible cause of my problem? I must confess that I haven't the slightest idea what ASIO and EASI are.
Cyril N. Alberga
not in 24 bits.
Cyril N. Alberga
