I want to let you know I like DCM alot, but have been having on going inconsistences with the multi-filter. In my current setup I use an impulse-CNF-harmonic combination.
First, when I run preview and toggle the bypass box on and off, the left and right channels appear to switch sides.
Second, I save settings in MF by double clicking on the individual filters, setting them the way I want them, previewing, then saving the settings in MF. However sometimes those settings don't seem to stick. And when processing a wave file MF does not always follow the saved settings.
If after selecting a saved setting, I double click on the individual filters sometimes the settings will be correct and sometimes not. Tonight for example, I made an adjustment to the CNF for 20db reduction with a certain curve, but even after repeated saves, when I re-opened MF and click on CNF the filter setting was at 90db.
Any ideas?
Thanks, Alan
Any ideas?
Thanks, Alan
