I'm looking at some mp3's that were unfortunatly recorded at 64kbps. Can Millenium help compensate for what was lost in this low quality translation or should I look into another product?
mp3 as source
Re: mp3 as source
The multifilter has a preset or two for improving the quality of MP-3's. If you want to set up your own enhancer, use the Virtual Valve amplifier set to the 12AT7 triode and adjust the paramaters until the high end is regenerated. Alternative, you could put the VVA in Exciter mode and adjust the operating point and mix controls for the best balance of harmonic injection. Next, apply the punch and crunch in expand mode to restore the lost dynamic range of the recording. Lastly, try applying a little EQ with either the Graphic or Paragraphic EQ."Who put orange juice in my orange juice?" - - - William Claude Dukenfield
