When in the typical restoration sequence of an old 78 should the equalization be adjusted to remove the RIAA curve put in by the preamp and apply the 78 turnover.
I've been doing it after rumble/low pass, impulse and median filtering.
Some day I will buy an adjustable preamp if I can find one at a reasonable price. Also the manual talks of choosing stylii of appropriate size. Where do you get those? So far I have only found 1 for my cartridge. I think it s 3 mil and the shape is not specified.
