Problems with v. 4.80
  • Problems with v. 4.80
    I recently upgraded from v.4.64 to v.4.80 by using your patch. When using the inf in sync mode and alternating between play and preview, the program would soon crash and I had to restart my computer. I had this problem occationally on earlier versions, but not as consequently as on 4.80. I am now back to 4.64, which does not appear to have this problem at all.
    My OS is Win-95.
    Regards
    Terje
    Re: Problems with v. 4.80
    Does not anybody at Diamond Cut want to comment this? Is there any reason why I should have this problem on this particulsr version?
    Terje
      Could you please clarify what the inf is. Do you mean the Impulse Noise Filte?
        Yes, I mean the Impulse Noise Filter. Sorry for the confusion. I should perhaps add that this happened when I had selected a short portion of about 2-3 seconds of the wavefile. Then after alternating between play (destination file) and preview (source file)a few times, to test the effect of the filter settings, the program would crash. I got the message that the program had carried out an illegal operation and would be closed. When restarting the program it would not function, and I had to restart my computer.
        This happened several times, and in the end I gave up and reinstalled Millenium and upgraded up to 4.64, which does not have this problem at all.
        Terje
          We will try to replicate this. Will advise.
