Slowing track down.
  • Slowing track down.
    Hi
    I have several tracks that are fast so i want to slow them down using the change speed function.
    I used the predefined 6% and ran "Run"....but i am getting...
    "Caution! The Pitch Change operations has changed the length of the destination file. Further processing in Sync Mode will lead to unpredictable results. Use the Make Destination The Source function to start a new file."
    so, I used the "Make Destination The Source" to start a new file ran the function again and it then gave me the same message.
    Any suggestions?
    Thanks
    Dave
    Hi -
    Go to the "View" menu and uncheck the "Sync Files" function and it should work fine.
    keywords: sync mode error message, change speed filter error message
