Just a quick question about paste - mix.
If you were to paste mix the left channel of a signal to the right channel, would you get the same result as doing a file conversion of mono l+r?
I guess the question is whether past mix is a simple summation or not.
I have mono-sourced material recorded on two channels where one or the other channel varies in level at different times. I was wondering if simply reversing the file and then paste-mixing one file on top of the other would result in anything different from simply adding the two channels together into a mono wave file then making the mono file into a stereo file.
Thanks
Thanks
