I'm currently setting up a Multi filter to use with sound files containing mixed recordings of vocals, imported from cassette tape. I have 4 filters in the path ( so far )
Impulse Noise
Dynamic Noise
Median Filter
Bandpass Filter
I noticed that when I have all 4 filter windows open, and I click on Bypass in the multifilter window, only the Bypass tickboxes for the first two filters click on as well. The bypass tickboxes for the other two filters stay unticked. Testing the preview by changing the settings for the unticked filters shows that they are actually being bypassed, as intended.
By the way, I'd be happy to recieve any comments or suggestions on my multifilter setup. After using the multifilter, I would finish by using a CN sample, normalize, then quantize before CD burn. As I have over 130 cassettes to process, I am trying to set up a general setting that I can apply to all these tapes ( they all contain they same sort of material )
Mechi
Impulse Noise
Dynamic Noise
Median Filter
Bandpass Filter
Mechi
