I'm trying to use DC6 to clean up a recording of an interview that I captured from a webcast. I'm looking for advice on a couple of problems that puzzle me.
I have prepared a zip file which contains two sound samples, each a few seconds long. It is too big to upload (about a megabyte), so I am posting it at http://home.earthlink.net/~jonsachs/extract.zip.
Sample 1 illustrates background noise which occurs throughout the entire recording. (It appears to have been present in the source, since it disappeared when the source was broadcasting recorded announcements, etc.) I thought the Continuous Noise Filter would be the proper tool for eliminating this noise, but when I followed the instructions in the help file, I had very little luck with it. I took a noise sample from the noise in the silent period in the middle of the sample file, then ran the filter, but it did not noticeably attenuate the noise until I pushed attenuation up to about 90. Even there the attenuation was marginal, and at higher settings the sound quality suffered. Playing with the attack and release times did not seem to have any effect.
I had better luck with the Dynamic Noise Filter, but I found its instructions harder to understand, and I don't really know what I'm doing with it yet. Before I invest time in learning to use it now, I want to ask how to judge which filter I should be using. If the Continuous Noise Filter, what am I being wrong that makes it fail to work?
Sample 2 illustrates a problem that comes and goes at some points in the file. Here it sounds like an echo; and other points it sounds more like "crosstalk" from another program. Can DC6 clean up this type of problem? If so, what should I try?
