I have just ordered a out-board A to D converter, which I plan to use with my current sound card, a Creative Sound Blaster Live. However I stumbled over the following web-site:
http://www.pcavtech.com/soundcards/ct462044/index.htm
which indicates that this will actually give worse results than simply using the A to D facilities on the card itself. To paraphrase, the SB Live apparently runs at 48k bps internally, and will re-sample to 44.1k. In fact it is implied that the signal will be re-sampled TWICE, once to 48k, then back to 44.1k! Even if I run the out-board A to D converter at 48k there will still be one stage of re-sampling, apparently introducing distortions.
Is there another way (short of buying a pro quality sound-card) to do this? Does anyone know of a card which will simply accept a 44.1k digital signal and transmit the same, in a form that the converter will like? It doesn't need any of the usual sound-card stuff, I don't want to use it for playback, just capturing the digital signal.
P.S., anyone know how to link this input form with a spelling corrector????
