Summary: Like some other users, when I upgraded to Windows XP from Windows 98, I could no longer record or play 24 bit - I would get the infamous "capabilities" error message. Reverting to a somewhat older M-Audio delta-66 driver fixed the recording problem but I still can't play (or preview) 24 bit data.
Equipment details: Compaq Presario 5888 - AMD Athlon 700MHz, 384M Ram, Sound cards: M-Audio Delta-66 and Sound Blaster PCI 128. Note: I have the audio functions of the Blaster disabled - I only use the MIDI interface on it.
Things I tried that had no effect on the problem:
Disabling SoundBlaster audio features.
Disabling mapping to the Delta66 card.
Attempted to disable O/S use of Delta66 for system sounds - in case the O/S was changing the driver settings for the system sounds.
Tried what one user suggested - reducing display resolution (not sure why this would make a difference anyway)
Other pertinent info: I can record and play 24 bit files in Cakewalk/Sonar without any problem - including files that were recorded previously in DC Millenium back when I was running Win98. If Sonar can do it, why can't DC?
