preset saving fouled up
  • preset saving fouled up
    It is possible that the preset.ini file is at its memory limit of about 64 K. Because of this .ini limit, we changed that scheme to a better on in DC 5 and Live Foresnics using zip files for presets thus eliminating the memory limitation. This also allows users to share presets over the net.
    This has happened twice now within a couple of months time...without a clue VVA refuses to save a custom preset. I'll label a setting I like, click save, the label remains visable, run the VVA, close VVA, and then the next time I open VVA the settings I just save a couple of minutes earlier are not there...the label is not in the preset menu. Re-starting the machine makes no differenc. The only cure I've found is to do a dirty reinstall of DCArt. Anybody have an answer to this? Thanks!
    -Danny Gilbert
    Danny Gilbert
