Hi All,
Having some issues that others may be able to shed some light on.
Using a home-built PC with an AMD 4100 quad core processor (3.62GB) and 16GB ram (as the old one used to crash badly when running DC8 with 4GB ram)
To allow 16GB ram to be recognised by Windows, I installed Windows7 64bit
Two issues that I'm experiencing.
Anything complex (such as setting up a multifilter with more than four items) tends to reliably cause a system crash.
If you are replaying a recording and close the file, the sound will still keep running
I've found a workaround for the hang, which is to run the Windows task manager and resource monitor in the background.
Is there a fix to this or has anyone else had this problem? - irritating when you start a computer up and forget to run the task manager, only then to be met with a system hang.
Cheers,
AF
Cheers,
AF
