What are the underlined letters in the menus for?
  • What are the underlined letters in the menus for?
    I hope I'm asking this in the right forum, but I can't figure out how to use the underlined items in menus as a shortcut. For instance in the marker drop down menu, some of the items have an underline, some don't and some have it listed on the right side too. The label marker has the L underlined. Is there a keyboard shortcut or hot-key available using L? I've looked for this in the help, so if I've missed it, just guide me in the right direction. Thanks.
    The underlined "L" in the Marker Menu may be an error. Here are the "hot keys" (shortcuts) that are supported by the Diamond Cut DC8 family of products (as taken from the users guide/helpfile):
    Hot Key Index
    Here is a list of all known Hot Keys/Combos and their real world equivalent. These keyboard accelerators (sometimes just referred to as “Accelerators”) are listed below:
    "1" Play selected area + 0.25 seconds on each side
    "2" Play selected area + 0.5 seconds on each side
    “3" Play selected area + 1 second on each side
    "4" Play selected area + 2 seconds on each side
    "A" Select displayed area (same as double click)
    CONTROL+"A" Select entire file
    CONTROL+"C" Copy selection to clipboard
    "D" Select destination
    CONTROL+ "E" Select/deselect the pencil (need to be zoomed in far enough to see waveform)
    "I" INTERPOLATE Full File (Bi-Modal {BM})
    "J" INTERPOLATE LEFT channel only {BM}
    “SHIFT + I” INTEROPLATE LEFT channel only {BM}
    "K" INTERPOLATE RIGHT channel only {BM}
    “CONTROL + I” INTERPOLATE RIGHT channel only {BM}
    “O” INTERPOLATE (Time Domain Mode)
    "L" PLAY LOOPED
    "M" DROP MARKER
    CONTROL+"M" MUTE
    "N" GO TO NEXT MARKER
    CONTROL+"N" NEW File,
    SHIFT+"N" GO TO PREVIOUS MARKER
    CONTROL+"O" OPEN File
    "P" Open PREFERENCES
    Plus Sign (+) Zoom In X2
    Minus Sign (-) Zoom Out X2
    CONTROL+"P" PRINT
    “Q” Activates "Snap Selection to Zero Crossing"
    CONTROL+"R" Brings up Record screen
    "S" SELECT SOURCE
    CONTROL+"S" FILE SAVE
    CONTROL+"U" UNDO LAST EDIT
    CONTROL+"V" PASTE
    ALT+BACKSPACE UNDO
    SHIFT+DELETE CUT
    END REWIND TO Start
    F1 Launch HELP file system
    SHIFT+F1 CONTEXT SENSITIVE HELP
    F6 NEXT PANE
    SHIFT+F6 PREV_PANE
    HOME FORWARD TO END
    CONTROL+INSERT EDIT COPY,
    SHIFT+INSERT EDIT PASTE,
    LEFT ARROW NUDGE RIGHT edge of selected area to the left
    RIGHT ARROW NUDGE RIGHT edge of selected area to the right
    SHIFT+LEFT ARROW NUDGE LEFT edge of sel. area to the left
    SHIFT+RT ARROW NUDGE LEFT edge of sel. area to the right
    RETURN Default button (this is the cancel button on all filters)
    SPACEBAR Play File or Record/Pause (toggle) when the
    record dialog box is active.
    UP ARROW Increments the selected parameters
    DOWN ARROW Decrements the selected parameters
    CONTROL+"X" CUT
    "X" ZOOM OUT
    "Z" ZOOM IN
    CONTROL+"Z" ZOOM OUT FULL
    CONTROL+”B” Paste Bleep
    ALT+"S" Toggles between Spectrogram & Normal
    Mode
    Esc Exits from Direct Spectral Edit (DSE) Mode
    or from the Spectrogram
    Mouse Wheel Zoom In & Zoom Out
    Related Topics
    Charts, Graphs and Other Info
    Copyright (c) 1996-2013 Diamond Cut Productions, Inc.
      There are two different kinds of shortcuts here
      The underlined letters in the menus are shortcuts to that menu. These can be accessed by holding down the ALT key and pressing that letter.
      So for example, to get to the L, which is in the Marker Menu->Label Marker menu, do this
      ALT+M
      ALT+L
      So the first ALT+M gets you to the marker menu, and the ALT+L selects the Label Marker menu
      The second kind of shortcut keys are the direct access keys, those are the letters or key combinations that are seen in the menus to the right of the menu text, ex:
      Drop a Marker M
      Pressing the M key will select that menu directly.
      This is all standard windows stuff.
      Rick
        This is all standard windows stuff. .............................great... now I'm going to have to learn Windows!
          Dan,
          LOL - same here!
            Thanks for those answers. I thought I had tried all the usual key-combinations to get a result for the Label-marker command. So today, I tried the Alt-L after getting the Marker menu displayed, and it worked, but only sometimes. Other times it would release the Marker menu itself and I get a little ding from Windows. I looked under preferences, but didn't see any adjustments for that. Has anyone else had difficulty?
            Also, I learned today what the Drop-marker meant. I had read it to mean drop (or delete) marker, and not drop one at the current position. So I was adding markers all over the place. Then the light bulb went on and I like the term now.
              I think that the cursor needs to be right in the middle of the marker indicator (pentagon) for the system to recognize the marker to be labeled.
                OK. I think I've got it now. If I call up the Marker menu with the Alt-M and then type L by itself , it seems to work. Perhaps I had done that earlier, but when I used Alt-L , the Marker menu goes away.
