The Diamond Cut Forensics8 Voice Garbler - it's special
  • The Diamond Cut Forensics8 Voice Garbler - it's special
    The Diamond Cut Forensics8 Voice garbler can be a very important feature in Forensics work. It is a pretty unique feature. Yes, there are a lot of harmonizers and pitch shifters out there.
    The Diamond Cut Voice Garbler is much more than that. You see, harmonizers and pitch shifters are reversible processes. If you are trying to disguise somebody's voice using those sorts of things, they are very easily reversed and the persons identity revealed.
    The Diamond Cut Voice Garbler uses a combination of techniques making the disguised voice non - reversible. It may sound a bit crude, but it is not by any stretch. If it is really important to disguise a persons voice, the new Diamond Cut Voice Garbler is the one to use.
    Give youself a little challenge - - - Garble a Voice with the Diamond Cut Voice Garbler and then try to reverse it.
    The voice garbler was not invented just for fun. There are forensics situations in which a covert witness must remain anonomous subsequent to verbal testimony about a situation. This feature allows the recording of such a person and allows other persons to hear and understand the testimony without giving away the persons identity. Of course, this can be done with harmonizers and pitch changers, but those processes can be reversed (using Diamond Cut software). But, the Voice Garbler can not be reversed (even using Diamond Cut software) providing the witness with a reasonable degree of security.
