remove echo from oldtime radio
  • remove echo from oldtime radio
    Hello folks, I have downloaded some old radio recordings that sound as though they have been sent down a tube. What is the best way to get rid of this effect. they really do sound as if they have a small echo in the recording. I have tried reversing the echo in the echo reverse preset but to no avail. Any ideas would be a great help.
    Hard to say. Please send me a short sample of this at dctools@aol.com so that I can make recommendations.
      This is how I did it with a little direction pointing from Craig - paragraphic equaliser-1st reverse RIAA phono curve 2nd-RIAA phono curve improved 3rd- into Echo use reverse echo and bring the output mix down to about 20. it works a treat thanks Craig you were a big help.
        I am glad that it worked out for you.
          Craig - what does the reverse RIAA and then add RIAA do? It seems like it would just put it back where it was.
            What I heard sounded like a flat transfer to me - - - very hollow sounding. So, I just applied the RIAA curve to it and it sounded much better. I did not reverse the RIAA and then Re-apply it. That seems to be a mistake in the written transcription.
              OK - thanks. I was wondering.
