Group,
I'm confused on the channel blender and have some questions :
1. Does the "Blend to Mono" box just turn on a crossover filter in the signal path for the L+R or L-R (depending on the invert phase boxes ) signal ?
2. How does the rumble on lateral recordings get reduced ? Section 2 on pg 260 talks about the method, but I'm not following the concept.
The text says to add in low frequency signals (L+R) to the L and R chanel. How does that reduce the rumble ?
I understand that the L+R signal is the vertical component and that the filter means that the resultant signal that is added ...IS... the rumble, but how does the rumble get reduced if it's added in ? Wouldn't that make the rumble louder ?
