Octaves on Paragraphic Equalizer
  • Octaves on Paragraphic Equalizer
    Hi all
    If I want to draw a particular curve, I can't seem to get a smooth blue line. Is this important? Also, all set curves
    are based around 3 octaves. What is the significance of this?
    Phil
    London
    You can adjust the Octaves value for each band. Octaves represents the bandwidth of each band, the higher the Octaves value, the wider the bandwidth. You can adjust the band octave values to help create a smoother curve.
