Has anyone used a turntable weight or clamp while recording an l.p or 45. If so is there any benefit by using such a thing?
turntable weight
Hello Folks, I have made a weight and tried it out on Beethoven Moonlight sonata, it seems to brighten the music quite a bit there is not so much noise from the record as there was before using the weight. It weighs in at about 350 foriegn things ans is solid alluminium. can someone else try it
Hello Mark, If you look on http://www.soundfountain.com you will find a diagram with all the measurements required. more about the mechanics of record players and setting up the same. A man called Rudolf A Bruil edits the site and it has loads of interesting items on it. go on, have a look. dodgyrog,
