With just a few runs, it looks like:
96kHz can be more aggressive than 44.1. Especially with narrow crackle. Also getting good results with 88.2 sampling rate, which this card also supports. I don't see any difference in performance between the 88.2 and the 96 kHz sampling in terms of any distortion.
If I remember correctly, there was a suggestion in a thread at one point that 88.2 might be a better rate to use if the end product was a CD because of potential errors in downsampling, although I think there were minimal benefits.
48kHz sampling rate is providing good results, but you have to be less aggressive with the de-clicker.
If you use the VPA before de-clicking, the same settings on EZ-Click produce fewer click totals. The good information out of this is that it means you get less distortion because it's operating on fewer potential clicks. I can't really hear a difference in terms of click removal, but it's very evident during processing.
One thing I noticed, and I'm not sure what this means:
When I use the VPA to convert from the flat preamp file to a 'normal' file, at the higher sampling rates, I get a much 'louder' signal (according to the pkf). I'm not sure why that would be. That is, keeping the same setting and running the 4 files (I didn't touch the levels when I made the recordings) one after the other, I gain-normalized at -1.5dB.
gain-normalizing the 96kHz file lowered it (you could see the pkf 'shrink')
88.2 shrunk a little bit
48kHz increased considerably
44.1 increased more.
These were visible in the pkf file before I did the normalizing (and why I did the normalizing). I just did it again to make sure I was accurate, and got the same results. Would this be expected?
